Hello! LiveDisplay function doesn’t work correctly on iode 3.5-20230131-beyond0lte (samsung s10e, android 12). The problem occurs if Animation is disabled. If you turn off the animation (in the settings or in the developer options), then the LiveDisplay function works only until you lock the phone; after unlocking the phone the LiveDisplay function will no longer work.
Also, the LiveDisplay function stops working if you make any changes in the LiveDisplay section, such as changing the Color Profile, activating/deactivating Outdoor mode or Reading mode. It will happen even if you don’t turn off the animation.
Also, the LiveDisplay function stops working if you lock and unlock the phone very quickly; just quickly press the Power button twice and the LiveDisplay function will no longer work. It will happen even if you don’t turn off the animation.
Please fix this bugs. Thank you!
