In Feb 24s bèta 5 keyboard is missing
Openbboard is removed from my purposely installed apps.
In fdroid it cannot be added nor removed.
Heliboard is not available either.
Did you enable it in the system settings?
Heliboard a system app now and cant be uninstalled.
Thx, I found Heliboard now.
It was there indeed and previously I was looking at the wrong place (under Preinstalled apps and under Default apps). Found it under System etc).
It was again disabled just after the upgrade
Yes, the issue is known and will be fixed.
