Issues Beta Version
Hello team !
I’m currently experiencing two issues with the new Fairphone (Gen. 6) beta 7.4 update, released a day ago. These two issues did not occur with previous versions.
  1. First issue: the volume up button no longer responds. I can’t get it to work.
  2. Second issue: with the three-button navigation, the central button to return to the home screen isn’t working.
Thanks in advance :slight_smile:
I’ll pass that to the Beta Testers Telegram / Matrix channel.
A fixup beta OTA is out, with both issues solved.
