Hello everyone ![]()
I’m considering installing IodéOS and I was wondering if someone can confirm that Android Auto works ![]()
I’d like to get free from the Xiaomi default OS but I really need Android Auto connected to the infotainment system of my car
Not working
Oof. Thank you, I’ll keep an eye on the project
I’ll give it a shot once Google apps start working
It won’t start working in iodé by design
I really hope that this will not happen.
Android Auto for Google is a discontinued model. Every time a user opens the app, the message “Android Auto for smartphone displays will soon stop working” appears.
As an aside, Auto Android version 9.0.630834-release has implemented only one tracker, but - requires 59(!) (fifty-nine) permissions. Permissions are actions that the application can perform on your phone. This opens the door for Auto Android to deGoogled iodéOS system by Google LLC, USA.
Possible alternatives of Android Auto , some with advertising, are not a bit better (functions not tested by me):
AutoMate: 3 tracker 39 permissions (3/39).
AutoZen (3/27)
Drivemod: (9/50)
Waze (3/40)
Auto Dashboard (4/25)
Google has made it convenient and comfortable for users with Android Auto. But the price for that is the loss of privacy.
Bit late maybe but I’ve just made android auto work on Iode 4.4. You need to be rooted though and flash a stub in magisk. A guide and the zip to do this can be found here: GitHub - sn-00-x/aa4mg: Android Auto 4 microG
For android Auto to work you’ll also need the text to speech stub (available in the same package) and google maps and the google app. These need to be installed for Android Auto to launch but they don’t need to actually work or be connected. So I just installed them and then disabled all their permissions and network access. This way I can have android auto with waze and revanced youtube music in my car without the disadvantages. Hope this helps and can convince you to give Iode a try. Really loving the ROM.
Seems the latest stable has the patch or somethung similar. Anyone knows how to get it running since the patch had quite a few options and steps?
Since I switched to degoogled ROM’s, I rooted the head unit in my Honda using Honda Hack. This allowed me to side load navigation apps and introduce the capability for the system to play FLAC files stored in the USB thumb drive. ( I have hi-res music files on the drive in FLAC format) I simply connect the head unit to the internet via my phone’s hot spot. In that way, I can navigate, listen to music and take calls/messages as I drive.
Yes it works. Followed Iode installation instruction. Used the stub apps. Allowed AA notifications in trebuchet and voila!
ROM: 7.5-20260503-devon
