Iodeos v5 for pixel8
Hi…where can I find older roms for pixel 8?
Why do you want to use a outdated system?
Because root(lsposed) working better
I don’t think there is a good solution with iodé for old version builds. There are some A14 (so the “v5.x” series) builds for some devices that don’t support the move to A15, but I think the model they follow is to not maintain multiple base version series for devices.
Even if the last of the v5.x build was available, without it getting further releases it would be at risk since it wouldn’t be getting security patches, etc. so you would be on an island.
