IodeOs reboot by itself when I turn on bluetooth
Hello
I have a new issue with iodeos on fp5 : it reboots by itself when I turn on Bluetooth.
Could it means that FP5 may not have ressources for new versions of Android ?
Thomas
You may have mentioned this in other threads, but wondering how you installed iodé and what version you are on? What system was on the phone prior?
I’d try a factory reset and failing that RMA. I use Bluetooth on/off daily and never reboots. It did once reboot every time I plugged it into charge (in car, so similar time to when Bluetooth is used) but after turning off phone and back on it never did it since (in over a year).
Hello
Thank you for your answers
I bought my phone to Iode company directly
Currently it runs with Iode 6.5
Thanks again
I can confirm this behaviour. Although it has not happened in a short while, my FP4 also did restart after turning bluetooth on or off every now and then. I’m not sure anymore if that happened while turning WIFI on/off at the same time. But it’s really strange.
It doesn’t seem to be a “normal” restart as well as I don’t have to enter my SIM pin again.
Please email support@iode.tech with your details, and please report back here if you find any solution working with them.
I haven’t got answer from the support
I reinstalled iode os
Actually, I realised that it reboot also when I turn on Spotify
Thanks again for your answers
Thomas
