Hi all,
Is this message normal?
The Note on compatible recovery…I can’t remember if I’ve seen another like that before the previous updates…
Ja. Völlig normal.
Thank you so much! Got worried for no reason…
Hi all, After the update my battery drains in a few hours. Can I get back to my previous version??? I can’t use the phone the way it is now…
yes, from scratch.
via fastboot way with loosing all data and settings
This is probably less due to the update than to an app that doesn’t run cleanly in the background. Try restarting a device or two, or delete the cash partition if your device is doable.
