neeohw
8 February 2026 16:01
1
I was wondering when version 7 will officially be supported for Fairphone 4
The forum says it is supported, the official list not, but the shop sells Fairphone 4 with iode 7. Then installation package for installing it yourself again says only 6.12
Will it be available for update any time soon?
I am now running 6.12 on my Fairphone 4
Hi, neeohw,
searching the forum gave me this answer: FP4: Iode 7 status / Issue Tracker? - #7 by rik
neeohw
8 February 2026 18:03
3
Alright, thanks. Don’t know why it didn’t come up in my search results
I used the key word* Fairphone4.
(If you add it to your post, others will find it more easily.)
don’t know if keyword is the right name, in German it displays as “Schlagwort”, right next to the Categories.
rik
9 February 2026 18:04
5
I’ll also post here the link to our gitlab issue tracking the problem: Fairphone 4: iodéOS 7.x builds (#71) · Issues · ota / issue-tracker · GitLab
But as already noted, it is best to use the FP4: Iode 7 status / Issue Tracker? post for further comments or questions.
