I have a Pixel 8 and have updated from iodé 6.3 to 6.4. Now with 6.4 when I answer an incoming call it automatically switches phone speaker on and cannot switch it back off.
I tried to install new phone app from F-droid but it does the same: does not allow to turn off speaker, so the problem it is not with the phone app itself, rather a system setting. Phone restart did not help either.
Did anybody experience the same? I was looking for any global setings to disable auto speaker on call but did not find anything.
Is there any setting I can do or is it a global issue?
Thanks in advance for sharig your experience/thoughts.
@Jolly0326 if you could update to 7.2 and re-test it may be solved.
To upgrade to version 7, you need to first install an update to the “Updater app” itself, as described in our iodé 7 release announcement: iodéOS 7 is Now Officially Available! - iodé So follow the link there to install the v6-to-v7.apk and then the upgrade to 7.2 should proceed.
The reason this one-time manual process is needed is due to LineageOS (our upstream source) making a change that disabled major version upgrades by default.
