Hello to the forum,
I have the problem that some system setting are not saved and therefore don’t take effect, for example:
- I changed the notification sound to “none” but the system still plays the “Argon” sound
- I disabled the option “sound in lock screen” (e.g. when unlocking) but I still get an audio notification
- I changed the the clock design from digital to analog on the lock screen but the digital clock is still displayed
Does somebody made similar experiences and is there a solution/workaraund to “convince” iodéOS 5.5 to save and apply my settings?
Regards
“Klaus”
