Iodé tracker don't work🛑
Hello, it’s been several versions of iodé OS A that the iodé tracker blocker(3.1.2) no longer detects my applications and therefore no longer seems to block trackers, what can I do? It only detect the new app I download
Thanks for your regards
Ps:I have a xiaomi mi10lite M2002J9G under Iodé OS A 4.17 bought at the end of 2022
hi
save your individual settings… 3 dots top right… then reset the blocker… under general settings… possibly delete the blocker’s cache under apps…
then reload your individual settings.
then start all apps once… then they should work again.
greetings
