There are websites that connect me further through to google play store, insisting that I install their app. How can I instruct Iodé browser not to follow the google play link?
I hope I understand your question corrected. You can block the link in iodé firewall.
Kind regards.
Thx! Where is that firewall?
Its the iode app in the system
I cannot adapt anything there.
Apart from that it only shows some coloured grahs.
In German:
Falls das auch gewünscht wird:
Du kannst die Weiterleitung von externen Links direkt im Browser unter Einstellungen unterbinden, oder nur auf Nachfrage öffnen lassen.
If that is also desired:
You can disable the forwarding of external links directly in the browser under settings, or only open them on request.
Best regards
El
