Iodé blocker
How to add an Internet address as a database for the “iodé” blocker
To customize the blocklists you would need to be a “Premium” subscriber. Here is a bit more info on using the iodé app (including how to add custom addresses): iodé app - iodé
In addition there is this page, which is lower level explaining how the blocker works:
How do I create my own list?
Par exemple: “https://sebsauvage.net/hosts/hosts”
I’m a premium user.
Thank you
Not possible atm
OK I understand better, you would like to add an additional block list (sorry I didn’t understand before). As @AlphaElwedritsch mentions, it isn’t possible at this time, but I submitted a feature request: iodé blocker: add custom block list file (#33) · Issues · ota / issue-tracker · GitLab
In the documentation I read that it is possible to add a customized list:
Blocking Databases
Database Sources
The blocker offers different levels of blockings:
  • Complementary Blockings: Options to block adult content, unethical social media, and customized lists (avancé) défini par l’utilisateur.
If you long press on this “customized blockings”, it allows you to add individual rules one at a time, including a wildcard or a regular expression. So it is about using these individually added rules, not about adding a list of rules. But as noted, I think it would be a good feature to be able to add a full list as you request, that is what I suggested on the feature request.
Sorry I was simply wrong. An internet address cannot be added as a custom source as the original poster inquires about, but adding a local custom blocking list is possible: “iodé app > Settings > Custom blockings > 3 dots > Import”. In order to put your list into a format recognized by the blocker, you can “backup” your current blockings to reference the format.
