Since the new update im unhappy with the iode blocker.
First i had to reset it so that it works again and not just ignores all the connections and doesnt display apps that are connected to the web. And now the default blocking doesnt work.
Bad
Bad
I need it to work as whitelisting mode so that apps just cannot connect
What update do you mean? What device?
Please send iode version string from settings/about phone, like:
4.4-20230823-redfin
3.9-20230824-monet
Let me update my monet snd see what happens…
Update
Ok, im on the same version now.
Everything works as expected.
Did a reset of the app. But again, all works…
Cannot reproduce your issues
the app is just the gui of the deep system blocker
in your case, there must be broken in the system
there was already something to do with another user.
similar symptoms
I can’t remember where and when that was exactly.
I’m sure @vince31fr can say more about that
A similar situation occurred some while ago indeed, and has been fixed thanks to a user who tested several beta versions until a solution was found. This may be a different problem here, I cannot tell anything without data.
You have two possible solutions :
