Iode blocker map problem Sony 10v install
Just carried out a PDX235 install and everything seems to be working ok however, bringing the map up inside the iode blocker package I get this…….
Looked through the app settings but can’t find anything relevant to the source to toggle or adjust. Any ideas welcomed.
Which iodé version?
Is it related to Iodé app: Internet connection analysis app did not show map ?
Yes it would appear so. This install is the latest (v7.1) as the Sony 10 v isn’t officially supported so maybe I need to inform @petefoth so he can bear it in mind for the next update if he’s not already aware of it. Thanks for the link.
iodé 7 builds are currently in progress for the Sony devices, including 10 v pdx235. The 7.3 buuild for pdx235 should be done by tomorrow morning. Follow build progress in the MicroG LineageOS builds Matrix room https://matrix.to/#/#microg-lineage-os-builds:matrix.domainepublic.net
