Io.ktor.client.plugins error
My system shows sometimes io.ktor.client.plugins.ClientRequestExeption, i.e. when trying to update installed apps via Fdroid, sometimes while using the Netflix-App. Does anyone know what causes this error?
original fdroid client or any other third party client?
It is the original one, preinstalled by iodé
no solution, but I get the error too sometimes
I’ve always assumed it to be an non-reachable server or something - and it always worked again a couple hours / a day later
I get the same, and started getting the error about 2 weeks prior to 5.8 dropping.
If you go into FDriod Settings and turn off the iode repo, the error will go away. Turn it back on, it comes back. But it is random for me in the same way as @Privateer mentioned.
Same problem here (FP4 with iodéOS 5.6)
