The alternative he talks about is Curve, and it should work just as well with IodéOS - and Iodé Blocker dealing with the privacy issues - as he says it does with /e/OS and their ‘Advanced Privacy’. You get a card (for use in ATMs) as well as an Android (or iOS) app for NFC payments
I decided it is time to start experimenting with ‘payment by phone’. I’ve installed Curve (from Aurora Store) and added one of my debit cards. Now let’s see if it works
The debit card I added is Visa (as are pretty much all the cards I own) and I could add it with no problem. Is this the only positive effect of Brexit?
What about Revolute Pay? Anybody has any experience with it? It is implemented into the Revolut itself. But I never used it, so no direct experience on my side.
