Installer stuck at "Downloading configuration" 100%
Using the installer, on both Linux and Windows, I get as far as:
“Preparing the installation
Plug your device to a computer and turn it on…
…while we configure the installer
Downloading configuration - 100%”
And then nothing happens, I’ve waited many minutes. My device is the Pixel 7a. Any help would be appreciated. Thanks in advance.
When ran from the terminal:
./iodeOS-installer
Gdk-Message: 15:50:40.453: Unable to load from the cursor theme
[ERROR:flutter/runtime/dart_vm_initializer.cc(40)] Unhandled Exception: FormatException: Unexpected character (at line 653, character 7)
"FP4",
#0 _ChunkedJsonParser.fail (dart:convert-patch/convert_patch.dart:1463)
#1 _ChunkedJsonParser.parse (dart:convert-patch/convert_patch.dart:852)
#2 _parseJson (dart:convert-patch/convert_patch.dart:35)
#3 JsonDecoder.convert (dart:convert/json.dart:641)
#4 JsonCodec.decode (dart:convert/json.dart:223)
#5 jsonDecode (dart:convert/json.dart:160)
#6 new Configuration.fromJson (package:installer/config_provider.dart:43)
#7 Config.fetch (package:installer/config_provider.dart:179)
<asynchronous suspension>
The Installer had an online metadata issue that I understand was just fixed. Can you try again?
I’ve since manually installed iodéOS and everything worked fine :smiley:
