Hi, I wanted to install IodéOS on my Fairphone 3, but I can’t find the fastboot package.
Where can I download it from?
Thank you ![]()
The installation with iodéOS 5.x for Fairphone 3 unfortunately failed several times.
I then installed iodéOS 4.x for Fairphone 3 and everything worked perfectly.
Unfortunately, IodéOS 4.x is unavaible on website ![]()
Il will try the new 5.7 or with the installer…
From here I would have this release v4
