Hi all,
Very often when I’m using my phone and someone calls me, there’s no screen popping up to allow me to pick up the call.
I have to go to the notifications screen (dragging down from top) and then find the call notification to be able to answer…
This is of course very annoying.
I looked up in every parameter menu but couldn’t find any solution.
Does anybody know hox to fix this ?
Cheers,
Jean-Pierre
Up
anyone ?
Thanks for the answer, but alas, no call waiting function activated…
Is it also with another dialer? Fossify for example
Look at Settings > Notifications. The last entry Heads-up should be enabled.
If not, do so and try again.
Yup, that’s it ! Many thanks @silta
