A whitelistfunction for paranoids xD
A function to just temorarly allow permissions and after amount x is taken away again.
The blocker should work also in the workprofil.
Spermprotecting function xD : shut off connections when screen is off.
It is, at least if you mean shelter, etc…
You can switch it off and then on again
Yes manually but it would be great if i give a permission it is taken away automatically after x minutes.
