Hey everyone,
I installed iodeOS on my phone & I am enjoying the minimal, privacy-focused experience so far. I am facing issues with how apps behave in the background. few important apps such as email and messaging seem to stop syncing unless I open them, even though I have turned off battery optimization for those apps.
I have gone through the usual settings under Apps > Battery and even adjusted permissions but nothing seems to stick. Are there any extra tweaks or settings I should be aware of to make sure background services run smoothly ?
On a side note, while trying to troubleshoot, I came across a post suggest the Salesforce Developer Course Online which made me think — maybe understanding some back-end logic could help me figure out what’s happening here. Also i have check there Battery optimization app setting? witch is good. still need help.
Thank you…![]()
