How to Create a PDF from a JPEG
currently I use a Pixel 7 that runs Android 16 and Iodé 3.1.7
How can I create a PDF from a jpeg file created with the camera ?
Well, I’m simple. I copy the photo in a document and export the document as .pdf
Not really Iodé, but here you go.
This app has the ability
Image Toolbox: GitHub - T8RIN/ImageToolbox: 🖼️ Image Toolbox is a powerful app for advanced image manipulation. It offers dozens of features, from basic tools like crop and draw to filters, OCR, and a wide range of image processing options · GitHub
Or “OSS Scanner” on F-droid
Have you tried to print your photo directly from the photo Gallery ?
I have several photo apps installed on my phone, like Aves, ReFra, Fossify Gallery or the default Gallery app on iOdé.
For each one, there is a way to print.
You can try to select your picture, click on “share” and then select “print”.
Hope this helps.
I went through a cumbersome process.
I sent the JPEG to my wife. She uses Adobe Photoshop on her PC and, of course, created the PDF in two minutes.
I’ll look into your suggestions, but it might take a little longer. Thank you very much for your support.
@CORTO333 did you try this simple app?
Thanks, but somebody propose using directly the Camera application and print from it. And a PDF is created…
