How to create a folderwith a name in order to group apps and sort them
I have just installed Iodé on my new Fairphone 5.
How to create new folder in the home screen, in order to group apps with same theme.
On Android, I could easily long press on 2 app icons and “select elements” → “create a folder”.
Thank you very much.
Take one icon and pull it onto the second
Thank you very much for the very quick answer. So easy!!!
when you have set everything up on the home page the way you wanted it… you can then lock the layout and also hide the icons that you dragged onto the home screen on the second page… I personally find this clearer.
to do this, simply hold your finger on the home screen for a longer time… then settings will appear… you can adjust a lot of things there
