How to Add Emoji Dictionary to HeliBoard
I am assuming that Heliboard is installed as standard as all my keyboards on Fossify, Brave browser, etc., look the same. I want to add a dictionary primarily to Fossify Messages so that I can use the Heliboard emojis dictionary. These are the instructions that I see:
To add a dictionary file for emojis to HeliBoard, follow these steps:
  1. Download the emoji dictionary file (e.g., emoji_en.dict ) from the official repository, such as the aosp-dictionaries repository on Codeberg.
  2. Open HeliBoard and navigate to the Languages & Layouts settings.
  3. Select the language for which you want to add the emoji dictionary.
  4. Tap the + button next to the “Dictionary” section.
  5. Choose “Add dictionary from file” and browse to select the downloaded .dict file (e.g., emoji_en.dict ).
  6. The dictionary will be added, and you should now receive emoji suggestions as you type, providing a functionality similar to “emoji search”.
Question: where is the Heliboard app stored or how do I access it?
Open Heliboard, in the german version long press the comma button, (right to the ?123 button bottom left) a popup appears, select the gear symbol and that you are in the settings
Thank you. That helped me execute the instructions but I’m not seeing emojis. I will investigate and maybe open another topic.
On the english keyboard, in addition to the , to the left of the space and to the right of the ?123 buttons, you can long-press the “orange return key” on the keyboard, then 2 more orange keys appear, the first one being a “smiley face” which will open the emoji selector screen.
