How can I hide Trebuchet?
Hello community,
There’s an app that runs in the background, but also shows its face in the notifications bar of my phone that has been annoying me ever since I installed iode. It’s called Trebuchet. I understand it blocks malicious stuff from various apps and so it needs to run all the time. But isn’t it possible to set it so that I don’t see it in the notifications all the time? It’s icon also appears next to the small clock at the top left corner of the screen, which is also annoying. It confuses me that there is a new important notification, when there isn’t.
I wanted to attach some screenshots here to show you, but I don’t know how to take a screenshot?! Despite the fact that I often take a screenshot by mistake when someone is ringing me and I swipe up to pick up. Then it works! But I don’t know how?
by using the search function here in the forum.
sorry but it’s always boring to answer the same questions
in settings of iode app, you can disable notifications
Yes, I did search up “Tribuchet” in the forum here, but didn’t find anything relating to my question, hence why I posted.
Thanks, [AlphaElwedritsch] it worked! And I cannot believe how simple and straightforward that was! I don’t know how come I wasn’t able to get to that screen before. I guess I got frustrated because I kept on clicking on the notification, which didn’t lead me to the app.
Anyway, silly story! Thanks!
But that disables all notifications from the iodé app. Normally I would like to see all notifications except that nonsense one about Trebuchet. Is there a solution for that?
No
All or nothing :wink:
What a pity. AFAIR that was better in previous versions of iodé.
it’s been a long time.
Version 3.1.2 at least 1 year old.
this is, like many things, a purely subjective matter of opinion
Well, when I did what AlphaElwedritsch said it worked for me. The mistake I was making up to this point was that I would always try to click on the Trebuchet notification, hoping it will take me to the source of my annoyance. But it did nothing, which annoyed me more and so I put the phone down. But if you go to all apps and click on the Trebuchet app from there, go to its setting and you can switch off ITS notifications. I haven’t noticed my other notifications being switched off. I still get notifications from the calendar, sms, missed alarm, etc.
To clarify: Trebuchet is the launcher for iodéOS.
The iodé blocker (displayed simply as iodé in the launcher/Trebuchet) blocks Internet connections and displays this notification. If you have another app open (e.g., Calculator) and pull down the notification, the app name (in my example, Calculator) will appear instead. iodé does not block any elements of Trebuchet because Trebuchet never accesses the internet. And so there is no configuration option because there is nothing to block in Trebuchet.
