Hi everyone, ![]()
I am new to the IODev community and could use some help. I recently decided to switch from Windows to IODev, but I am having some trouble with the installation process on my laptop. I have downloaded the ISO file from the official website and created a bootable USB drive using Rufus. However when I try to boot from the USB, my laptop does not seem to recognize it. I have checked the BIOS settings and made sure USB boot is enabled.
Could anyone guide me on what I might be doing wrong or suggest any steps I might have missed. Also, if there are any detailed guides or tutorials that you recommend, I would really appreciate it. Looking forward to being a part of this community and learning from all of you.
I have already read this article
https://edu.gcfglobal.org/en/basic-computer-skills/installing-software-on-your-windows-pc/1-devops-architect/ but i could not found any correct information.
Thanks in advance for your help.
Best, ![]()
[Maria]
