Heliboard is crappy
I am not very happy with Heliboard. Issues:
  1. After selecting one of the offered word suggestions on the top row above the keyboard, more often than not a completely different word emerges as a result.
  2. The spacebar, rather than inserting a space, very (VERY) often shifts the cursor to the left, straight into a word that was typed just earlier.
Using 5.5 beta
Mostly using Dutch on Heliboard
As harsh as that may sound, the best keyboard is and remains the Google keyboard, Gboard.
I have done a lot of tests, tried out all kinds of keyboards. But in the end, if good autocorrect is important to you, you want to use glide typing and the keyboard should simply run smoothly, then you can’t get past Gboard.
I use Gboard and forbid it from using the network. This way, security and privacy are guaranteed, but I don’t have to be annoyed every day with every sentence I write.
I’m also using heliboard with a library for swiping and I’m quite happy with it. The main downsides for me are the german dictionary - it lacks a lot of words and autocorrect suggests sometimes pretty stupid stuff. But that’s the cost of a no-data-collecting keyboard and the best I tested so far.
You do this in the apps privacy settings?
In case of iodeOS in the iode blocker app for gboard
You mean in this manner?
Or like this:?
I don’t use gboard but I would deactivate this switch in the app settings:
Guys you’re both right.
Both is possible and do the same in the end
Well, sometimes when I restart my phone the iodé blocker is turned off. That may be an issue that only concerns my phone but turning the network off in the app settings seems to be more secure to me.
yes, it’s a point of trust
Since I also could not use the very basic keyboard because I came from Swype and this didn’t work anymore, I now use https://keyboard.futo.org/
But swiping is still quite in development.
It’s using offline data also for speech recognition, not only for typing.
But heliboard doesn’t seem to be so bad at second sight:
I agree with both your feedback. Concerning item 2: indeed the keyboard seems to trigger a cursor move (left mainly) even when not intended.
This leads to often typing characters on the left of the current cursor instead of typing a space and is quite annoying indeed.
However, I found out that this feature is optional and it can be disabled via Heliboard’s settings (it was tricky for me to find how to open these settings though, so here is the process I followed:
Go to Android Settings → Keyboard → Keyboard on display.
You will see a list of available keyboards (or maybe just one), including HeliBoard.
If you long press here (on the name Heliboard, not one the enable/disable switch on the right), it will open Heliboard’s settings.
Go to Advanced Settings, find the setting for horizontal swipe on space bar and set it to No action.
You should not get unintended cursor moves anymore when pressing the space bar.
Heliboard’s settings can be accessed directly from within Heliboard (although I’m using stock Heliboard from F-Droid, the iodé version presented problems and I had to disable it).
Press the arrow button to the upper left of the on-screen keyboard, then the cog icon, which should be immediately adjacent. In case this isn’t visible you might need to use the left/right arrows to scroll the toolbar.
If you forbid network access to gboard, do autocorrect and word suggestions still work?
