Hardware Question - Internal Memory Durability?
Hoping someone in the community understands hardware durability.
I had a microSD in my car since 2017. It was loaded with music. The tracks I played most often began to fail after about…4-5 years. I was singing at the time and these were tracks I used to practice with: many, many times over. After the aforementioned time, the tracks degraded and began skipping, screaching, not playing.
I could only surmise degradation/damage to the sectors on which these tracks were recorded.
Does the same thing happen with the internal memory of the phones we use? I’ve a Pixel 9a (new) and listen to a meditation recording nightly to fall asleep. I’m not keen on having the memory degrade creating bad sectors.
Any suggestions, caveats, insights would be helpful.
Thanks very much.
Yes all flash storage (and spinning disks alike) are all subject to failure, but will it be before the end of the devices life, or the end of our lives :-)? I have not yet (personally) seen phone storage fail.
All SSDs / flash storage are built with a certain amount of tolerance for managing some sector failures, this is all within design spec. You will find that microSD cards have much cheaper build quality / lower tolerance and will fail much quicker due to read/write wear.
I guess without doing a lot of detailed research, I would (again only personally) suggest this isn’t a practical concern but let’s see if others from the community can give a bit more substance to this statement :slight_smile:
Here is a dump from a general search, for your reference, when I search Flash Memory lifespan.
The general rule seems ot be 10 years or less, depending on the quality and technology used. I think this would apply to all types, in general. This is something that also pertains to optical disks (cds).
My general feeling is “my needs would outgrow the usefullness of the device” before it fails. I have a whole box full of small, useless sd cards and keys, none which have failed. But I’ve also had one or two fail in the last few years.
Sorry for the long post :slight_smile:
Understanding Flash Memory Lifespan
Flash memory lifespan refers to how long a flash memory device can reliably store data before it begins to degrade or fail. This lifespan is primarily determined by the number of write and erase cycles the memory can endure.
Key Factors Influencing Lifespan
*Write/Erase Cycles: Flash memory is rated for a specific number of write/erase cycles, typically ranging from 10,000 to 100,000 cycles for standard devices. High-end models can exceed one million cycles.
Quality of Materials: The manufacturing quality of the flash memory affects its durability. Higher quality materials generally lead to longer lifespans.
Environmental Conditions: Extreme temperatures, humidity, and dust can negatively impact the lifespan of flash memory. Storing devices in optimal conditions can help preserve data integrity.*
Estimated Lifespan of Flash Drives
Type of Flash Drive Estimated Lifespan (Years) Write/Erase Cycles
Standard USB Flash Drive 10+ 10,000 - 100,000
High-End USB Flash Drive 10 - 100 Up to 1,000,000
Low-Quality USB Drive Less than 10 Fewer than 10,000
Under ideal conditions, data on a high-quality USB flash drive can remain intact for at least 10 years. However, frequent use and poor storage conditions can lead to data degradation sooner.
Conclusion
While flash memory is a convenient storage solution, it is not ideal for long-term data archiving. Regular backups on more stable media, such as external hard drives or optical discs, are recommended for important data.
NAND Flash Memory
NAND flash is widely used for general data storage. It is characterized by:
High Density: Can store large amounts of data in a compact form.
Sequential Access: Data is read and written in blocks, making it faster for large data transfers.
Types:
Single-Level Cell (SLC): Stores 1 bit per cell, offering high performance and endurance but lower capacity.
Multi-Level Cell (MLC): Stores 2 bits per cell, balancing cost and performance.
Triple-Level Cell (TLC): Stores 3 bits per cell, providing higher capacity at a lower cost but with reduced endurance.
Quad-Level Cell (QLC): Stores 4 bits per cell, ideal for read-intensive applications but has lower performance and endurance.
NOR Flash Memory
NOR flash is optimized for applications requiring fast random access. Its features include:
Random Access: Allows data to be read in any order, making it suitable for code execution.
Lower Density: Generally used for smaller storage capacities compared to NAND.
Applications: Commonly found in embedded systems, firmware storage, and devices needing quick access to data.
Summary of Key Differences
Feature NAND Flash NOR Flash
Access Type Sequential Random
Density High Lower
Typical Use General data storage Code execution, firmware
Performance Faster for large data Faster for small data access
Endurance Varies by type (SLC > MLC > TLC > QLC) Generally lower than SLC
Flash memory is essential in various devices, including USB drives, SSDs, and memory cards, due to its speed, reliability, and compact size.
And it depends very much on how full the flash memory is. The fuller, the shorter the lifetime.
Here is a good link to a pdf for Macronix SLC NAND flash. It’s technical but elaborates very well what happens over time.
Endurance and Data Retention SLC NAND FLash
@rik, @papercut, @volker01 Thanks for taking the time to respond. Interesting information and appreciate learning. Upshot will not be worrying about the phone memory failing. While I’ve held onto my phones for a particularly long service life: upgrade from a Samsung S10 to a Pixel 9a, the most recent transition, it shouldn’t be an issue.
This rabbit hole does make me wonder/ponder/imagine: Why don’t we have something that is nearly indestructible with regard to memory at this point?
Thinking along these lines: A slice of crystal or lab grown diamond that is written with a laser to cut the information in and then read with a laser that can NOT cause any damage. It would seem this sort of arrangement would not cause degradation to stored information that becomes essentially read only.
Not necessarily practical, just a thought.
From my limited knowledge, reading should cause far less wear than writing. Either of which should be well within the device life span for regular use, unless you’ve listened to those tracks millions of times. I’d be more inclined to blame data corruption from “Read Disturb” or maybe heat damage. See:
Maybe something else is writing to the card causing premature damage?
Like most things today, the answer is money. Things that last for ever only sell once.
We’ve been hearing “They don’t make them like they used to” since our grand parents. Most business models today are based on reduced product quality, and planned obsolescence, and the ability to sell us a new ones sooner rather than later.
Also, in these days of streaming and the everything in the “cloud”, the demand for local storage has sadly been declining.
For flash memory in smartphones (usually UFS 3.1 / 4.0 / 4.1 since 2024-2026, still eMMC for very cheap models), similar physical principles apply to SSDs:
Garbage Collection, Wear Leveling and Write Amplification need some free space to work efficiently.
However, the situation is much more relaxed in practice than with PC SSDs - mainly because of the following differences:
smartphone controllers usually have very generous internal over-provisioning (often 10-30%, with some models even more), which the user does not see at all.
The typical daily amount of writing is much less than on a PC (usually 1-10 GB/day instead of 20-100 GB).
Modern UFS memory (from UFS 3.1/4.0) are extremely well optimized for mobile workloads → Performance drops noticeably only very late. iOS and Android manage the memory aggressively (e.g. clear cache, clear temporary files automatically).
Realistic recommendations for smartphones (as of March 2026) Smartphone memory
Typical use (photos, videos, apps, social media, normal use)
Keep minimal (still ok)
Recommended (sweet spot)
When do you notice problems?
128 GB Flash Memory:
8-12 GB (~6-10%) at least free
15-25 GB (~12-20%) recommended
below ~5-7 GB free. problems…
