Hi!
To the best of my understanding, the sha256 file is missing for iode-5.11-20250401-arm64_ab.img at Files · master · ota / betas · GitLab . I didn’t find it in gsi · master · ota / release · GitLab either.
Would it be possible to add it to your repos?
Thanks!
Clément.
The recent release at gsi · master · ota / release · GitLab , iode-5.12-20250507-arm64_ab.img.xz (for which I’m thankful!), is also coming without a sha256 file.
How can I check the integrity of my download before flashing?
Thanks a lot for releasing the iode-5.13-20250523-arm64_ab.img.xz file! I unfortunately have the same question as before: how can I check the integrity of my download before flashing? Thanks!
rik
August 6, 2025, 5:17pm
4
Issue created . Vincent is swamped but hopefully will get a chance to post the .sha256sum when he gets a chance.
Thanks a lot for creating the issue @rik , I really appreciate it.
