Anyone know how to get black and white icons for iode os
I believe you will need to use an alternate launcher, as Trebuchet (the default LineageOS / iodéOS launcher) doesn’t support this level of customization: https://www.reddit.com/r/LineageOS/comments/16ci4os/how_do_i_change_the_default_app_icons_on_lineageos/
If you go to settings/display/live display there is a reading mode that put everything in black and white, not only the icons but maybe that is what you are looking for
You may want to try some diifernt launchers. There is one I noticed in F-Droid called Ion Launcher that provide black and white icons. I am pretty sure there are some others too…
