Google Pixel 9 Pro
Hello to the forum,
I bought a “Google Pixel 9 Pro” to use GrapheneOS (because it’s said that GrapheneOS is currently the safest Android OS).
But I’m a little disapointed from GrapheneOS (due to the fact that I need to install Google Play Services as a sandboxed app which has not the full functionality. I hoped that it will support a full Google Integrity Check - because it’s Google :'-) But using the app Integrity Checker (https://play.google.com/store/apps/details?id=gr.nikolasspyr.integritycheck) attests me only BASIC INTEGRITY.
Because I read in the MicroG project that they made progress in implementing a “fake” Google Integrity Check, I’d like to return to iodéOS if my “Google Pixel 9 Pro” will be supported officially :slight_smile: Are there any information if this is planned?
Best regards and Merry Christmas to all community members
“Klaus”
download.lineageos.org/devices
doesn’t look like it.
If it isn’t supported there… then it’s not supported by iode either… because it’s based on it
Hi evicence-it,
thanks for info. Sad to read…
But hope dies last :slight_smile:
But it may not be long :slight_smile: - see
Hi petefoth,
I’m not familiar with github-things, so please excuse my question:
So that means “There is a light at the end of the tunnel and it is not an on coming train”?
That would be really cool…
Thanks for info :slight_smile:
I think so. I’m just not sure how long the tunnel is :slight_smile:
