GCam port for Samsung phones
Hey there,
is there a working port for googles camera app for samsung s9 / s10 devices? I tried to start the normal app after downloading it from aurora store, but it crashed instantly.
Actually, I liked the easiness of aperture cam and the feature-rich open camera app but wanted to try and see what differences there are.
Regards
Thanks for the fast reply, gotta try that!
After trying a couple of ports I went back to Open Camera for stability reasons. Most of the BigKaka Versions crashed at startup. The only ones working were AGC8.4.300_V9.9 and ZGCAM7.4 V1.03415 but both had problems finding the selfie cam or the ultra wide lens. How did you get the V9 and V11 running @sts61 ?
I use an S10e with iodéOS 4.9
Well, so there is no way the selfie and wide lens are working? Having microG installed should not be the problem, I guess.
So maybe I just give up and stick to Open Camera for now.
If anybody has come across a working gcam port for s10e exynos that doesn’t crash regularly, pls let me know!
I use an older version with the WonIT config: Config Files for BSG 8.1
All lenses are working on S10+
But i dont really use it that often because Apeture works great
Has anyone tried this recently?
