Garbled sound - A5 (2017) - iodéOS 2.41
Hello all
Sorry if this post is not in the right cat,
Just updated my A5 from 2.38 to 2.41 (build 2.41-20260122-a5y17lte), and the sound playback isn’t working anymore, there’s just a garbled “pssshhhht” sound that is played whenever some sound is supposed to be played.
I did a factory reset, but the issue stays.
Here is some logcat info, when trying to choose the ring sound in sound settings
02-21 22:06:08.752  2772  2812 E BufferQueueProducer: [NotificationShade#0](id:ad40000007c,api:0,p:-1,c:2772) disconnect: not connected (req=1)
02-21 22:06:10.173  3925  3925 E PhoneInterfaceManager: [PhoneIntfMgr] getIccId: No UICC
02-21 22:06:10.204  3925  3925 E PhoneInterfaceManager: [PhoneIntfMgr] getIccId: No UICC
02-21 22:06:10.220  3925  3925 E PhoneInterfaceManager: [PhoneIntfMgr] getIccId: No UICC
02-21 22:06:10.246  3925  3925 E PhoneInterfaceManager: [PhoneIntfMgr] getIccId: No UICC
02-21 22:06:11.184  2832  3560 E Utils   : did not find channel-count and/or sample-rate
02-21 22:06:11.185  2832  3560 E Utils   : did not find channel-count and/or sample-rate
02-21 22:06:11.218  2832  3560 E Utils   : did not find channel-count and/or sample-rate
02-21 22:06:11.229  2850  2863 E OMXNodeInstance: setConfig(0xf1a800f0:google.vorbis.decoder, ConfigPriority(0x6f800002)) ERROR: Undefined(0x80001001)
02-21 22:06:11.245  2769  2769 E ServiceUtilities: Request requires android.permission.MODIFY_PHONE_STATE or android.permission.WRITE_SECURE_SETTINGS
02-21 22:06:12.362  2832  3560 E Utils   : did not find channel-count and/or sample-rate
02-21 22:06:12.389  2832  3560 E Utils   : did not find channel-count and/or sample-rate
02-21 22:06:12.389  2832  3561 E Utils   : did not find channel-count and/or sample-rate
02-21 22:06:12.409  2850  2863 E OMXNodeInstance: setConfig(0xf1a800f0:google.vorbis.decoder, ConfigPriority(0x6f800002)) ERROR: Undefined(0x80001001)
02-21 22:06:12.430  2769  6602 E ServiceUtilities: Request requires android.permission.MODIFY_PHONE_STATE or android.permission.WRITE_SECURE_SETTINGS
02-21 22:06:20.302  2772  2813 E BufferQueueProducer: [com.android.soundpicker/com.android.soundpicker.RingtonePickerActivity#0](id:ad40000007d,api:0,p:-1,c:2772) disconnect: not connected (req=1)
02-21 22:06:20.332  2832  3561 E Utils   : did not find channel-count and/or sample-rate
02-21 22:06:20.334  2832  3560 E Utils   : did not find channel-count and/or sample-rate
02-21 22:06:20.369  2832  7554 E Utils   : did not find channel-count and/or sample-rate
02-21 22:06:20.369  2832  3560 E Utils   : did not find channel-count and/or sample-rate
02-21 22:06:20.379  2832  7554 E Utils   : did not find channel-count and/or sample-rate
Did anybody encountered the same issue?
Thanks for any help
Just flashed 2.43 firmware update, bug has been corrected, sound is back normal :smiley:
Glad to see it is working well again, thanks for reporting back!
