Hi All, please, I have heard that many banking apps won’t work if the phone cannot lock the bootloader. If this is true, I might not be able to use banking apps on Galaxy A52S?
Unlocked bootloader is not a big issue for most banking apps. What is more important is whether devices pass SafetyNet and / or Play Integrity tests. My experience is that some bank apps which don’t work on e.g. LineageOS for microG - which does not pass SafetyNet - do work under IodéOS.
But it very much depends on which banking app. If you tell us which app you want to use, then maybe someone who uses that app can tell you whether it works under IodéOS
Hi, thank you for your reply. So, the baking apps are the following: IBKR Mobile interactive brokers; Schwab Mobile; Chase Mobile; Wise; Nomad and Nubank. Thank you
Wise works
I own too a A52s 5G and I wonder if you have been able to solve your problem and, especially, if you had to re-lock your bootloader.
I encounter some problem with apps and it seems to require locked bootloader…
