France Identité on FP5 - can it work?
Hi.
Has anyone succeeded to get France Identité working on iodé 6.6?
Hi, It’s working for me on every version of Iode since the app was released.
What’s your error?
At start, I have a French flag with Marianne profile inside and a spinning wheel below.
After about a minute, I get the following error:
Oups ! Une erreur est survenue. Merci d'essayer ultérieurement
My bootloader is still unlock. It looks like I need to wait for a more recent security patch.
I sometimes had that on the first start after an unpdate.
Did you try to clear the cache? Reboot the phone?
Oh yes, many times :slight_smile: No luck.
Something I just noticed, I have now Safetynet certification test failing. I have installed Magisk and struggled to uninstall it. Maybe it is the reason why.
Coud it be an issue?
That being said, I am sure France Identité had the same behavior before I inistalled Magisk. One reason to install Magisk was to install France Identité with root rights, but has not brought any improvement.
Hi. After updating to iodé 6.7, I was able to lock again my FP5.
However, France identité still does not work; same behavior ending with the error message.
Hi. It looks like an /e/OS update has improved / solved the issue?
Any insight on how it might be applicable soon for iodéOS?
I’m checking with the team on if it is working for them or not.
Hi @rik
Any news? Anything I could test to help?
I did get this reply, sorry I failed to post it back here:
This app works on pixel with bootloader relocked, but not on fp5. I think there’s a problem on hardware attestation on fp5 (issue from lineage), but I can’t find information from /e/, they probably made something
To your link to /e/, iodé official builds are already user builds and not userdebug builds, and we also have microG version 0.3.9.250932 which is newest release available. So it isn’t those 2 parts that are at fault here (it may take further digging / inquiry with /e/ to sort out what they did).
I confirm this
On a fairphone 6 with murena ( /e/ os) I could use France identité without any problem.
I wanted iodé for the material you ( /e/ does not support it) so I have sent back the phone and bought a iodé phone.
On the FP6 on /e/ os, France identité was working perfectly
On the FP6 with iodé, impossible to get it working :frowning:
Thanks for the feedback.
With iodé 7.4 and latest microG update, I still cannot get France Identité to work on my FP5.
