Hallo all,
now it happend to me ![]()
i tried to relock the bootloader, but i forgot to push the custom key.
Now my FP4 did not boot anymore and only fastboot is available - when I select the recovery mode then it starts again in fastboot mode.
I installed iodeos 3.3 in the correct way with unlocked bootloader and i did not unlock_critical!
Everything went right an the os installation was completed. I did the first start and activated adb again.
For the last step, i wanted to relock the bootloader.
i tested : fastboot flashing get_unlock_ability
(bootloader) get_unlock_ability: 1
OKAY [ 0.000s]
And now locked the bootloader. That it …
I tried to erase the key
I started from beginning with flash recovery and then installing the key.
but i can´t reach adb
adb : List of devices attached
811xxxx unauthorized
after flashing again the recovery no adb connection was possible - so a sideload was not possible
No chance - only the bootloader - fastbootmode is available.
Seems to be bricked ?! Or had anyone an idea here?
That would be wonderfull.
thanks and greetings
Stephan
