I am right now trying to install iodé 6.8 on my Fairphone which had CalyxOS before. The installer (Linux) seems to stick here:
Erasing 'avb_custom_key' OKAY [ 0.010s]
Finished. Total time: 0.013s
Sending 'avb_custom_key' (1 KB)
No progress since about an hour. I am afraid there is a problem, or is this normal? How long should I wait? What will happen if I cancel the process?
This was the state of my phone before starting the installer:
~ # fastboot oem device-info
(bootloader) Verity mode: true
(bootloader) Device unlocked: true
(bootloader) Device critical unlocked: true
(bootloader) Charger screen enabled: false
OKAY [ 0.001s]
Finished. Total time: 0.001s
~ # fastboot flashing get_unlock_ability
(bootloader) get_unlock_ability: 0
OKAY [ 0.000s]
