Hello everyone, I have a problem with f-driod. There is an error message and I only see Iode apps in the repository. All other iode apps are not displayed. Surely all pre-installed apps from iode should also be displayed? Is this a bug?
I have a different address for the package source.
However, I have an Xperia XA2, but I think you should have the same information.
Yes, I have that too, but there are two repos. The standard repro and the one from Iode. The Iode repro is for the forked apps from iode.
Solved. I have deleted the Iode repro and reinstalled it. Now all iode apps are back.
Thans lot for solution. In my case help and now f-droid work ok.
