I need some assistance. I’m following this guide to flash /e/OS 7.3 on my FP6, and I have followed all the steps strictly.
I used the script included in the zip, and I got this log:
fastboot: error: Device does not support slots
Erasing ‘avb_custom_key’ OKAY [ 0.012s]
Finished. Total time: 0.033s
Sending ‘avb_custom_key’ (1 KB) FAILED (Status read failed (No such device))
mke2fs 1.47.2 (1-Jan-2025)
Creating filesystem with 16384 4k blocks and 16384 inodes
Allocating group tables: done
Writing inode tables: done
Warning: skip copying metadata image avb footer due to sparse image.
Sending ‘metadata’ (204 KB) OKAY [ 0.006s]
Writing ‘metadata’ OKAY [ 0.006s]
Finished. Total time: 0.047s
Erasing ‘metadata’ OKAY [ 0.007s]
Finished. Total time: 0.016s
Warning: userdata type is ext4, but f2fs was requested for formatting.
Info: Debug level = 1
Info: Trim is disabled
Info: Set conf for android
Info: Enable Project quota
Info: open /dev/loop0 failed errno:13 - be careful to overwrite a mounted loopback file.
Info: Sections per zone = 1
Info: sector size = 512
Info: total sectors = 437425048 (213586 MB)
Info: block size = 4096
Info: add quota type = 0 => 4
Info: add quota type = 1 => 5
Info: add quota type = 2 => 6
Info: format version with
“6.14.0-37-generic”
[f2fs_init_sit_area: 743] Filling sit area at offset 0x00600000
[f2fs_init_nat_area: 777] Filling nat area at offset 0x01600000
[f2fs_add_default_dentry_root:1393] Writing default dentry root, at offset 0x29e00
[f2fs_write_root_inode:1439] Writing root inode (hot node), offset 0x29800
[f2fs_write_default_quota:1531] Writing quota data, at offset 00029e01 (1/2)
[f2fs_write_default_quota:1531] Writing quota data, at offset 00029e02 (2/2)
[f2fs_write_qf_inode:1582] Writing quota inode (hot node), offset 0x29801
[f2fs_write_default_quota:1531] Writing quota data, at offset 00029e03 (1/2)
[f2fs_write_default_quota:1531] Writing quota data, at offset 00029e04 (2/2)
[f2fs_write_qf_inode:1582] Writing quota inode (hot node), offset 0x29802
[f2fs_write_default_quota:1531] Writing quota data, at offset 00029e05 (1/2)
[f2fs_write_default_quota:1531] Writing quota data, at offset 00029e06 (2/2)
[f2fs_write_qf_inode:1582] Writing quota inode (hot node), offset 0x29803
[f2fs_update_nat_default:1620] Writing nat root, at offset 0x00001600
Info: Overprovision ratio = 0.310%
Info: Overprovision segments = 335 (GC reserved = 329)
[f2fs_write_check_point_pack: 969] Writing main segments, cp at offset 0x00000200
[f2fs_write_check_point_pack:1056] Writing Segment summary for HOT/WARM/COLD_DATA, at offset 0x00000201
[f2fs_write_check_point_pack:1070] Writing Segment summary for HOT_NODE, at offset 0x00000202
[f2fs_write_check_point_pack:1082] Writing Segment summary for WARM_NODE, at offset 0x00000203
[f2fs_write_check_point_pack:1096] Writing Segment summary for COLD_NODE, at offset 0x00000204
[f2fs_write_check_point_pack:1104] Writing cp page2, at offset 0x00000205
[f2fs_write_check_point_pack:1146] Writing cp page 1 of checkpoint pack 2, at offset 0x00000400
[f2fs_write_check_point_pack:1165] Writing cp page 2 of checkpoint pack 2, at offset 0x00000405
[f2fs_write_super_block:1198] Writing super block, at offset 0x00000000
Info: format successful
Sending ‘userdata’ (89 KB) OKAY [ 0.003s]
Writing ‘userdata’ OKAY [ 0.006s]
Finished. Total time: 0.193s
Sending ‘frp’ (512 KB) OKAY [ 2.430s]
Writing ‘frp’ OKAY [ 2.056s]
Finished. Total time: 5.924s
Sending ‘abl’ (239 KB) OKAY [ 0.007s]
Writing ‘abl’ OKAY [ 0.006s]
Finished. Total time: 0.034s
Sending ‘aop_config’ (19 KB) OKAY [ 0.001s]
Writing ‘aop_config’ OKAY [ 0.004s]
Sending ‘aop’ (311 KB) OKAY [ 0.009s]
Writing ‘aop’ OKAY [ 0.005s]
Finished. Total time: 0.042s
Sending ‘bluetooth’ (812 KB) OKAY [ 0.020s]
Writing ‘bluetooth’ OKAY [ 0.004s]
Finished. Total time: 0.052s
Sending ‘cpucp_dtb’ (11 KB) OKAY [ 0.001s]
Writing ‘cpucp_dtb’ OKAY [ 0.005s]
Finished. Total time: 0.036s
Sending ‘cpucp’ (199 KB) OKAY [ 0.006s]
Writing ‘cpucp’ OKAY [ 0.004s]
Sending ‘devcfg’ (47 KB) OKAY [ 0.002s]
Writing ‘devcfg’ OKAY [ 0.001s]
Finished. Total time: 0.030s
Sending ‘dsp’ (65536 KB) OKAY [ 1.575s]
Writing ‘dsp’ OKAY [ 0.031s]
Finished. Total time: 1.632s
Sending ‘featenabler’ (102 KB) OKAY [ 0.003s]
Writing ‘featenabler’ OKAY [ 0.001s]
Finished. Total time: 0.035s
Sending ‘hyp’ (1642 KB) OKAY [ 0.041s]
Writing ‘hyp’ OKAY [ 0.002s]
Finished. Total time: 0.071s
Sending ‘imagefv’ (51 KB) OKAY [ 0.002s]
Writing ‘imagefv’ OKAY [ 0.001s]
Finished. Total time: 0.031s
Sending ‘keymaster’ (430 KB) OKAY [ 0.011s]
Writing ‘keymaster’ OKAY [ 0.002s]
Finished. Total time: 0.044s
Sending ‘multiimgoem’ (11 KB) OKAY [ 0.001s]
Writing ‘multiimgoem’ OKAY [ 0.005s]
Sending ‘qupfw’ (59 KB) OKAY [ 0.002s]
Writing ‘qupfw’ OKAY [ 0.001s]
Warning: skip copying shrm image avb footer (shrm partition size: 0, shrm image size: 51952).
Sending ‘shrm’ (50 KB)
It seems to get stuck at “Sending ‘shrm’.” Do you have any idea what might be going on? I must admit, I’m not sure what to do.
Cheers,
