Hello! I really like your operating system. Unfortunately, on the pixel 6, I had to skip some releases. I’m interested if I update the OTA software on lineage with microg, will it work?
Is the lineage-microg firmware on the phone right now, if I flash it via OTA iodeOS, will it work?
Or, use fasboot update instead of fastboot - w as an option?
In general, I flashed it clean through fastboot. The question is closed)). I returned to the bundle: iode + kernel bluespark. Thanks
What advantage do you hope to gain from the bluespark kernel?
Hi! Better system responsiveness, reduced phone heat, built-in KSU
What’s KSU?
Root, KernelSU
