Maybe it is helpful for somebody:
I switched multiple Fairphones (3/3+) from /e/OS to IODE - here are my first impressions:
good: the IODE-OS-installer worked flawlessly.
great: all apps (including a lot of proprietary apps) are working even with IODES highest block/protection level
annoying: the IODE-Trebuchet-window cannot be closed (alway displaying the connections), blocking space
one question too much: When I click on the Bluetooth tile, it asks me again if I want to switch on Bluetooth… (when I click on WLAN it just activates it …)
So far so good for me.
What’s missing?
Good backup-solution … but this was discussed and seems really hard. Maybe one could instead try to deeper integrate Nextcloud for backups.
Privacy-enhancing and out-of-the-box-integated Auto-off WLAN and Auto-off-Bluetooth (there once was Greentooth for bluetooth, for WLAN there is WIFI-Automatic) and maybe for VPN WG Tunnel.
Parental controls: Your solution is a good start but it doesn’t work for me as I need to restrict the actual screen-time. Maybe have a look at timelimit.io, also a very privacy-focused app.
Keep up this good work!
