Dear developers,
I have two Fairphones 4. One running IodeOS Beta 4.4-20230815-FP4 Android 13 and one running Fairphone 4 FP4.SP2J.B.086.20230729 Android 12. So for me its easy to compare the operating systems.
I would really like to have an option to choose between the 2.4 GHz band and the 5.0 GHz, which is possible on the original firmware. See the screenshots. Thanks in advance and keep on the good work!
Kind regards,
Guillermo
