Trying to install iode OS on a FP3. I have adb and fastboot in the latest version running on linux. I follow this guide.
Here’s the erorrs I get when I start the flash-all.sh:
Sending ‘userdata’ (316 KB) OKAY [ 0.040s]
Writing ‘userdata’ OKAY [ 0.029s]
Finished. Total time: 0.245s
fastboot: error: ANDROID_PRODUCT_OUT not set
fastboot: error: failed to open zip file ‘iode-4.1-20230401-FP3-img.zip’: I/O error
Rebooting into fastboot OKAY [ 0.020s]
< waiting for any device >
I have downloaded the mentioned file again.
Any input would be highly appreciated.
In general the guide for the installation failed, because my adb and fastboot were too old.
So what did I do?
I downloaded the platform tools from here:
They include the latest versions of adb and fastboot.
Then I made sure that no legacy versions of the tools were on my system:
sudo apt-get remove adb fastboot
Then I copied the unzipped files over to my linux system, while being in the folder where the unzipped files were:
sudo mv * /usr/local/bin/
Like this you can use the adb and fastboot commands wherever you are on your system.
Hi, I had this issue too when trying to flash my device - I added the following line to resolve that:
export ANDROID_PRODUCT_OUT=/path/to/the/directory/containing/binary/images/
with export -p one can list environment variables
