Fakestore update issue
Hi all,
fakestore update seems not to work. Does anyone have the same issue?
Is there any workaround?
I went to pre-installed apps and uninstalled fake store, re-started the phone, installed fake store and re-started the phone again.
see also the chat group
Hi @AlphaElwedritsch
thanks for the confirmation. The issue occurred on a 2nd phone as well. On the 1st try the fix didn’t work. The reason was a pending OS update not yet installed. After installing that, the fix worked.
May you paste a link to the chat group where you took the screen shot from? I think it would be interesting to follow the conversations there.
Kind regards
Andi
It should be better to wait for the upcoming 4.4 release, which will be out in a couple of days. It contains the FakeStore app with the correct signature.
This broke the Google Play Services(microG) for my Signal app.
The iode update 4.4 fixed all issues for my GalaxyS10e
