If anyone here has a Fairphone 5 using some version of Iode I just wondered if you could help with some things:
Can you run Iode with a locked bootloader?
With the bootloader locked, do you get a “yellow” warning about a custom operating system?
Context: I have a Murena Fairphone 5. Very dissatisfied with /e/ (Fairphone 5 version at least) so plan to try Iode. I am waiting for next release (rollback protection, cba with beta).
When flashing “avb_custom_key” I do get some kind of warning from fastboot.
I did but my phone just bricked, not sure if its because avb_custom_key flashing failed or because of security rollback protection. Currently waiting for Iode 6 to have another go.
Thanks, sadly thats just an OTA, I need a fastboot release. I will wait until 6 goes live. No experience with Iode, hopefully not too long between beta and release.
edit: I installed 5.8 stable using Fastboot, but commented out the bootloader locking. Then I installed the 6.0 beta OTA using recovery. At this point I locked the bootloader.
Seems to be working very nicely! I am sure someone will be along to tell me what I did wasn’t supported
