I’m running into an issue when trying to install iodéOS on my fairphone 5 with the iodeOS installer for linux. I have enabled OEM unlocking and USB debugging and the iodeOS installer makes my phone go to the boot menu.
The iodeOS installer then keeps hanging on the screen in this picture:
I have a few options with my fairphone when in the boot menu:
Start → starts my phone like normal.
Restart → the phone goes black and then returns to the boot menu.
Reboot in recovery mode → gives a new menu.
Power off → turns the phone off.
It looks like the iodeOS installer does not detect my device anymore after the previous steps. When I unplug my phone from the computer, the installer remains on the same screen.
Does anyone know how to proceed from here?
I would have liked to attach more pictures for reference but the forum doesn’t allow me because I’m a new user.
If your run windows on your computer, I suspect a driver problem. Check the device manager when your phone is connected in bootloader mode (which should be the case, at this stage).
bad usb cable (use a good cable, shuld be USB-A to USB-C)
try another USB port
Flashing as non-root
On traditional Linux distributions, USB devices cannot be used as non-root without udev rules for each type of device. This is not an issue for other platforms.
On Arch Linux, install the android-udev package. On Debian and Ubuntu, install the android-sdk-platform-tools-common package.
that common package ist mandatory
otherwise, the device will be detected, also with adb devices but fails when trying to install a ROM
doesn’t matter if fastboot, sideload or installer (i think)
Using a USB-A to USB-C cable instead of USB-C to USB-C.
Installing the android-sdk-platform-tools-common package (I’m running Linux mint)
I am getting much further now, but it is still not installing iodeOS. I have gone through the entire process and the installer thinks iodeOS was installed, but when the phone boots, a factory FairphoneOS starts. I have tried relocking and not relocking the bootloader after installation, both give the same result of starting FairphoneOS.
The output from the iodeOS installer is in the image. It did not allow me to copy the text so I had to paste some screenshots together, that’s why it might look a little bit wonky. My phone automatically moves between a few different menus during the installation steps.
Never mind, I tried it again and it worked. I used a different USB port on my computer, but not sure if that was the problem. I did not change anything else though. Thanks for the help!
I also had the problem, it was due to the fastboot driver. I had to select a newer one in the optional drivers under Windows. I didn’t know how to update the Android tools on Linux, so I installed it on Windows, with the other, newer driver
