When i try to download an app on F-Droid i get the following error:
The only workaround I found was to disable the privileged extension.
Is this caused because of an error while building? I built this by myself.
I raised this as an issue a while ago
A fix was made, and tested by me, but it seems the fix has not yet been merged into the main source branch (edit) and the code has been merged into the main source branch. I don;t know when it will be available in a released update
This fix is required for self-made builds, not for official builds: it is sufficient to update the source tree.
