I have been using iode on my Fairphone 4 for a while and decided to switch to an eSIM. But the activation process fails after downloading the eSim with a Message saying that my Mobile Provider could not be deactivated.
I tried this process several times, with slightly different results. Sometimes the dialog shows a loading spinner for over 10 seconds while other times it gives me the error message right away. Sometimes the app SIM Manager crashes.
Which brings me to my question: Is eSIM presently supported by iode?
I tried to record a logcat with the error, if this helps:
05-14 20:25:42.760 23480 23480 I ConfirmDialogFragment: Showing dialog with title =WeTell aktivieren?
05-14 20:25:42.787 1599 15881 D CoreBackPreview: Window{9749e59 u0 com.android.settings/com.android.settings.network.telephony.ToggleSubscriptionDialogActivity}: Setting back callback OnBackInvokedCallbackInfo{mCallback=android.window.IOnBackInvokedCallback$Stub$Proxy@977eef6, mPriority=-1}
05-14 20:25:42.795 23480 23496 E OpenGLRenderer: Unable to match the desired swap behavior.
05-14 20:25:42.799 23480 23496 W Parcel : Expecting binder but got null!
05-14 20:25:42.807 1599 15881 D CoreBackPreview: Window{8b855b8 u0 com.android.settings/com.android.settings.network.telephony.ToggleSubscriptionDialogActivity}: Setting back callback OnBackInvokedCallbackInfo{mCallback=android.window.IOnBackInvokedCallback$Stub$Proxy@f791564, mPriority=-1}
05-14 20:25:42.808 23480 23496 E OpenGLRenderer: Unable to match the desired swap behavior.
05-14 20:25:42.811 23480 23496 W Parcel : Expecting binder but got null!
05-14 20:25:42.819 1599 1849 I ActivityTaskManager: Displayed com.android.settings/.network.telephony.ToggleSubscriptionDialogActivity: +142ms
05-14 20:25:42.900 1011 1011 W SDM : HWCDisplay::GetHWCLayer: [0] GetLayer(16169) failed: no such layer
05-14 20:25:42.903 1060 1060 W HwcComposer: command 0x3000000 generated error 3
05-14 20:25:42.956 975 975 I android.hardware.power-service-qti: Power setMode: 5 to: 0
05-14 20:25:43.068 953 2241 I BTAudioProviderSession: UpdateTracksMetadata - SessionType=A2DP_SOFTWARE_ENCODING_DATAPATH, 1 track(s)
05-14 20:25:43.855 1599 2352 W InputReader: Received unexpected event (0x35, 0x394) for slot 0 with tracking id 10403
05-14 20:25:43.855 1599 2352 W InputReader: Received unexpected event (0x36, 0x4f1) for slot 0 with tracking id 10403
05-14 20:25:43.950 953 2241 I BTAudioProviderSession: UpdateTracksMetadata - SessionType=A2DP_SOFTWARE_ENCODING_DATAPATH, 2 track(s)
05-14 20:25:43.954 23480 23480 I ConfirmDialogFragment: dialog onClick =-1
05-14 20:25:43.954 23480 23480 I ToggleSubscriptionDialogActivity: User confirmed to enable the subscription.
05-14 20:25:43.976 23480 23480 V SidecarFragment: SidecarFragment.setState(): Sidecar Class: com.android.settings.network.SwitchToEuiccSubscriptionSidecar, State: State.RUNNING, Substate.UNUSED
05-14 20:25:43.989 23480 23480 I UiccSlotUtil: firstEsimSlot: 1
05-14 20:25:43.990 23480 23480 D SwitchToEuiccSidecar: The slotId1 is no MEP, port is 0
05-14 20:25:43.990 23480 23480 D SwitchToEuiccSidecar: set esim into the SubId4 Physical Slot1:Port0
05-14 20:25:43.992 23480 23480 V SidecarFragment: SidecarFragment.setState(): Sidecar Class: com.android.settings.network.SwitchSlotSidecar, State: State.RUNNING, Substate.UNUSED
05-14 20:25:43.993 1599 15881 D CoreBackPreview: Window{9749e59 u0 com.android.settings/com.android.settings.network.telephony.ToggleSubscriptionDialogActivity}: Setting back callback null
05-14 20:25:43.993 23480 23508 I SwitchSlotSidecar: Start to switch to euicc slot.
05-14 20:25:43.994 23480 23508 D UiccSlotUtil: The SimSlotMapping: [UiccSlotMapping (mPortIndex=0, mPhysicalSlotIndex=0, mLogicalSlotIndex=0), UiccSlotMapping (mPortIndex=0, mPhysicalSlotIndex=1, mLogicalSlotIndex=1)]
05-14 20:25:43.994 23480 23508 D UiccSlotUtil: The slot is active, then the sim can enable directly.
05-14 20:25:43.996 23480 23496 D OpenGLRenderer: endAllActiveAnimators on 0xb4000077148c04b0 (InsetDrawable) with handle 0xb400007624695370
05-14 20:25:43.997 1599 15881 W InputManager-JNI: Input channel object '9749e59 com.android.settings/com.android.settings.network.telephony.ToggleSubscriptionDialogActivity (client)' was disposed without first being removed with the input manager!
05-14 20:25:44.012 1599 1852 V WindowManager: Unknown focus tokens, dropping reportFocusChanged
05-14 20:25:44.042 23480 23480 V SidecarFragment: SidecarFragment.setState(): Sidecar Class: com.android.settings.network.SwitchSlotSidecar, State: State.INIT, Substate.UNUSED
05-14 20:25:44.042 23480 23480 I SwitchToEuiccSidecar: Successfully SimSlotMapping. Start to enable/disable esim
05-14 20:25:44.044 23480 23480 V SidecarFragment: SidecarFragment.setState(): Sidecar Class: com.android.settings.network.SwitchSlotSidecar, State: State.INIT, Substate.UNUSED
05-14 20:25:44.047 2743 2942 I EuiccController: isCompatChangeEnabled changeId: 224562872 changeEnabled: true
05-14 20:25:44.047 2743 2942 D EuiccController: subId: 4 portIndex: 0 forceDeactivateSim: false usePortIndex: true callingPackage: com.android.settings shouldResolvePortIndex: true
05-14 20:25:44.048 1599 1685 D CoreBackPreview: Window{5b64d2c u0 com.android.settings/com.android.settings.network.telephony.ToggleSubscriptionDialogActivity}: Setting back callback OnBackInvokedCallbackInfo{mCallback=android.window.IOnBackInvokedCallback$Stub$Proxy@45e28d7, mPriority=-1}
05-14 20:25:44.061 23480 23496 E OpenGLRenderer: Unable to match the desired swap behavior.
05-14 20:25:44.065 30115 30398 E AndroidRuntime: FATAL EXCEPTION: EuiccService #5
05-14 20:25:44.065 30115 30398 E AndroidRuntime: Process: com.google.android.euicc, PID: 30115
05-14 20:25:44.065 30115 30398 E AndroidRuntime: java.lang.UnsupportedOperationException: LPA must override onSwitchToSubscriptionWithPort
05-14 20:25:44.065 30115 30398 E AndroidRuntime: at android.service.euicc.EuiccService.onSwitchToSubscriptionWithPort(EuiccService.java:661)
05-14 20:25:44.065 30115 30398 E AndroidRuntime: at android.service.euicc.EuiccService$IEuiccServiceWrapper$10.run(EuiccService.java:910)
05-14 20:25:44.065 30115 30398 E AndroidRuntime: at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1137)
05-14 20:25:44.065 30115 30398 E AndroidRuntime: at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:637)
05-14 20:25:44.065 30115 30398 E AndroidRuntime: at java.lang.Thread.run(Thread.java:1012)
05-14 20:25:44.065 23480 23496 W Parcel : Expecting binder but got null!
05-14 20:25:44.094 3764 3764 D ClearcutLoggerService: onBind: Intent { act=com.google.android.gms.clearcut.service.START pkg=com.google.android.gms }
05-14 20:25:44.095 1599 30400 I DropBoxManagerService: add tag=system_app_crash isTagEnabled=true flags=0x2
05-14 20:25:44.097 30115 30398 I Process : Sending signal. PID: 30115 SIG: 9
05-14 20:25:44.098 3764 25124 D ClearcutLoggerService: bound by: GetServiceRequest{serviceId=CLEARCUT_LOGGER, gmsVersion=213604000, packageName='com.google.android.euicc', extras=Bundle[{}]}
05-14 20:25:44.126 1599 15881 I ActivityManager: Process com.google.android.euicc (pid 30115) has died: vis BFGS
05-14 20:25:44.126 1599 1934 I libprocessgroup: Successfully killed process cgroup uid 10113 pid 30115 in 0ms
05-14 20:25:44.127 810 810 I Zygote : Process 30115 exited due to signal 9 (Killed)
05-14 20:25:44.128 1599 15881 W ActivityManager: Scheduling restart of crashed service com.google.android.euicc/com.android.euicc.service.EuiccServiceImpl in 1000ms for connection
05-14 20:25:44.143 23480 23480 I EuiccOperationSidecar: Result code : 2; detailed code : 0
05-14 20:25:44.143 3764 25124 E JavaBinder: *** Uncaught remote exception! (Exceptions are not yet supported across processes.)
05-14 20:25:44.143 3764 25124 E JavaBinder: java.lang.RuntimeException: android.os.DeadObjectException
05-14 20:25:44.143 3764 25124 E JavaBinder: at android.os.Parcel.writeException(Parcel.java:2796)
05-14 20:25:44.143 3764 25124 E JavaBinder: at android.os.Binder.execTransactInternal(Binder.java:1304)
05-14 20:25:44.143 3764 25124 E JavaBinder: at android.os.Binder.execTransact(Binder.java:1244)
05-14 20:25:44.143 3764 25124 E JavaBinder: Caused by: android.os.DeadObjectException
05-14 20:25:44.143 3764 25124 E JavaBinder: at android.os.BinderProxy.transactNative(Native Method)
05-14 20:25:44.143 3764 25124 E JavaBinder: at android.os.BinderProxy.transact(BinderProxy.java:584)
05-14 20:25:44.143 3764 25124 E JavaBinder: at com.google.android.gms.common.internal.IGmsCallbacks$Stub$Proxy.onPostInitComplete(IGmsCallbacks.java:132)
05-14 20:25:44.143 3764 25124 E JavaBinder: at org.microg.gms.clearcut.ClearcutLoggerService.handleServiceRequest(ClearcutLoggerService.kt:28)
05-14 20:25:44.143 3764 25124 E JavaBinder: at org.microg.gms.BaseService$1.handleServiceRequest(BaseService.java:55)
05-14 20:25:44.143 3764 25124 E JavaBinder: at org.microg.gms.AbstractGmsServiceBroker.getService(AbstractGmsServiceBroker.java:258)
05-14 20:25:44.143 3764 25124 E JavaBinder: at com.google.android.gms.common.internal.IGmsServiceBroker$Stub.onTransact(IGmsServiceBroker.java:505)
05-14 20:25:44.143 3764 25124 E JavaBinder: at org.microg.gms.AbstractGmsServiceBroker.onTransact(AbstractGmsServiceBroker.java:274)
05-14 20:25:44.143 3764 25124 E JavaBinder: at android.os.Binder.execTransactInternal(Binder.java:1280)
05-14 20:25:44.143 3764 25124 E JavaBinder: ... 1 more
05-14 20:25:44.143 23480 23480 I ToggleSubscriptionDialogActivity: Failed to enable the eSIM profile.
