Dial the code *#*#4636#*#* (which spells *#*#INFO#*#*), select “Phone information,” and then the desired network type.
There was an issue identified with the 1.7.0-iode.14 version, so the 1.6.2-iode.15 was introduced to revert that. I understand that a new OpenEUICC version, 1.7.1 resolves the original issue with 1.7.0 and will be included in iodéOS 7.8 releasing in the very near future.
I hadn’t heard of people unable to open the reverted 1.6.2-iode.15 though, I hope the new update will fix that but let us know if you still can’t open it after 7.8 comes out.
Sure, will do when the new update arrives ![]()
Hey, so I tried the 7.8 today with OpenEUICC 1.7.1-iode17 and the good thing is that it works!
The bad news is that I still cannot open the app since the time that I uninstalled it and downgraded it. I got some android logs while opening the app in case they are useful:
09-02 22:36:13.391 2585 2585 D BaseActivity: Launcher flags updated: [state_started] -[state_window_focused] 09-02 22:36:13.392 9572 9572 D nativeloader: Configuring clns-9 for other apk /data/app/~~vLnUuCdHGp2Zz8-jAP6TSA==/im.angry.openeuicc-E5uXAhRY3aI3uzldRY3j9Q==/base.apk. target_sdk_version=37, uses_libraries=, library_path=/data/app/~~vLnUuCdHGp2Zz8-jAP6TSA==/im.angry.openeuicc-E5uXAhRY3aI3uzldRY3j9Q==/lib/arm64:/data/app/~~vLnUuCdHGp2Zz8-jAP6TSA==/im.angry.openeuicc-E5uXAhRY3aI3uzldRY3j9Q==/base.apk!/lib/arm64-v8a, permitted_path=/data:/mnt/expand:/data/user/0/im.angry.openeuicc 09-02 22:36:13.396 9572 9572 V GraphicsEnvironment: Currently set values for: 09-02 22:36:13.396 9572 9572 V GraphicsEnvironment: angle_gl_driver_selection_pkgs=[com.android.angle, com.google.android.apps.tachyon] 09-02 22:36:13.396 9572 9572 V GraphicsEnvironment: angle_gl_driver_selection_values=[angle, native] 09-02 22:36:13.396 9572 9572 V GraphicsEnvironment: im.angry.openeuicc is not listed in per-application setting 09-02 22:36:13.396 9572 9572 V GraphicsEnvironment: ANGLE allowlist from config: 09-02 22:36:13.396 9572 9572 V GraphicsEnvironment: No special selections for ANGLE, returning default driver choice 09-02 22:36:13.396 9572 9572 V GraphicsEnvironment: Neither updatable production driver nor prerelease driver is supported. 09-02 22:36:13.404 9572 9572 D AndroidRuntime: Shutting down VM 09-02 22:36:13.405 9572 9572 E AndroidRuntime: FATAL EXCEPTION: main 09-02 22:36:13.405 9572 9572 E AndroidRuntime: Process: im.angry.openeuicc, PID: 9572 09-02 22:36:13.405 9572 9572 E AndroidRuntime: java.lang.RuntimeException: Unable to create application im.angry.openeuicc.PrivilegedOpenEuiccApplication 09-02 22:36:13.405 9572 9572 E AndroidRuntime: at android.app.ActivityThread.handleBindApplication(ActivityThread.java:8144) 09-02 22:36:13.405 9572 9572 E AndroidRuntime: at android.app.ActivityThread.-$$Nest$mhandleBindApplication(Unknown Source:0) 09-02 22:36:13.405 9572 9572 E AndroidRuntime: at android.app.ActivityThread$H.handleMessage(ActivityThread.java:2690) 09-02 22:36:13.405 9572 9572 E AndroidRuntime: at android.os.Handler.dispatchMessage(Handler.java:132) 09-02 22:36:13.405 9572 9572 E AndroidRuntime: at android.os.Looper.dispatchMessage(Looper.java:333) 09-02 22:36:13.405 9572 9572 E AndroidRuntime: at android.os.Looper.loopOnce(Looper.java:263) 09-02 22:36:13.405 9572 9572 E AndroidRuntime: at android.os.Looper.loop(Looper.java:367) 09-02 22:36:13.405 9572 9572 E AndroidRuntime: at android.app.ActivityThread.main(ActivityThread.java:9287) 09-02 22:36:13.405 9572 9572 E AndroidRuntime: at java.lang.reflect.Method.invoke(Native Method) 09-02 22:36:13.405 9572 9572 E AndroidRuntime: at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:566) 09-02 22:36:13.405 9572 9572 E AndroidRuntime: at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:929) 09-02 22:36:13.405 9572 9572 E AndroidRuntime: Caused by: java.lang.SecurityException: Caller does not have permission. 09-02 22:36:13.405 9572 9572 E AndroidRuntime: at android.os.Parcel.createExceptionOrNull(Parcel.java:3373) 09-02 22:36:13.405 9572 9572 E AndroidRuntime: at android.os.Parcel.createException(Parcel.java:3357) 09-02 22:36:13.405 9572 9572 E AndroidRuntime: at android.os.Parcel.readException(Parcel.java:3340) 09-02 22:36:13.405 9572 9572 E AndroidRuntime: at android.os.Parcel.readException(Parcel.java:3282) 09-02 22:36:13.405 9572 9572 E AndroidRuntime: at com.android.internal.telephony.ITelephony$Stub$Proxy.getUiccCardsInfo(ITelephony.java:12715) 09-02 22:36:13.405 9572 9572 E AndroidRuntime: at android.telephony.TelephonyManager.getUiccCardsInfo(TelephonyManager.java:4317) 09-02 22:36:13.405 9572 9572 E AndroidRuntime: at im.angry.openeuicc.util.PrivilegedTelephonyCompatKt.getUiccCardsInfoCompat(PrivilegedTelephonyCompat.kt:89) 09-02 22:36:13.405 9572 9572 E AndroidRuntime: at im.angry.openeuicc.core.PrivilegedEuiccChannelManager.closeAllStaleChannels(PrivilegedEuiccChannelManager.kt:16) 09-02 22:36:13.405 9572 9572 E AndroidRuntime: at im.angry.openeuicc.PrivilegedOpenEuiccApplication.onCreate(PrivilegedOpenEuiccApplication.kt:15) 09-02 22:36:13.405 9572 9572 E AndroidRuntime: at android.app.Instrumentation.callApplicationOnCreate(Instrumentation.java:1400) 09-02 22:36:13.405 9572 9572 E AndroidRuntime: at android.app.ActivityThread.handleBindApplication(ActivityThread.java:8139) 09-02 22:36:13.405 9572 9572 E AndroidRuntime: … 10 more
Please try to reinstall the “Preinstalled Apps” version and restart and report back.
That worked actually! I just uninstalled the app from the iode store and install it through the “Preinstall Apps” menu and it works ![]()
